Re: Farmall 100 Steering Repair
Posted by gene bender on January 11, 2008 at 00:14:47 from (67.55.226.214):
In Reply to: Farmall 100 Steering Repair posted by Lewis on January 10, 2008 at 18:45:49:
You should have replaced the bushings and seals also the bearing on the end of the steering shaft a little play of this bearing makes for lots of wheel play was the gear tight on the shaft as that key can also get play. Are the balls on the tierods round or a little egg-shaped. I use a small disc sander and with calipers get them round again.A little here and a little there and soon you can have a lot of play. I have done 5 of them in the last few yrs and they all vary what it takes to make them steer like new.
