Farmall 100 Steering Repair
Posted by Lewis on January 10, 2008 at 18:45:49 from (12.189.32.37):
My 100 had an excessive amount of slack in steering gear box. All tie rod ends are tight. I removed the axle and the bearing at top of steering shaft was completely worn out. The gear was tight on the shaft and also the steering arm. I replaced the bearing and the steering is much tighter but I still have more slack than I think I should have; 12:00 TO 3:00. Any suggestions.
Thanks!
