Re: ih 350u
Posted by Janicholson on January 11, 2008 at 11:59:23 from (199.17.6.122):
In Reply to: ih 350u posted by greg t lang on January 11, 2008 at 11:34:41:
Georgeky is right. If the Fast hitch is accessible, and you have an implement like a disk, or plow, and it lifts them with good speed even at idle, I would look at other components, like a collapsed screen under the seat, or a partially non centered valve. If none is available to assist in the diagnosis, it is likely the pump. Small cylinders on the loader can have that effect, but if the loader has been on it for a long time, or is designed for the pressure, it needs a pump. They cannot be helped much with a rebuild. JimN
