Re: rear tires
Posted by RustyFarmall on January 11, 2008 at 13:33:51 from (209.152.78.71):
In Reply to: Re: rear tires posted by dennis repaal on January 11, 2008 at 12:33:08:
It does seem to get a bit expensive doesn't it?
Just keep in mind that you only have to buy new tires and fix up that old Farmall one time, and it will probably out-last you.
There are many other hobbies that are even more costly, but the cash outlay is not nearly as great at any one time, so folks involved in those hobbies do not consider them to be expensive.
As an example, what does it cost per ticket to attend a nascar event? And how often do some folks do that in one year? Add it all up, and it makes this old tractor hobby look pretty cheap by comparison.
