Re: rear tires
Posted by Andy Martin on January 11, 2008 at 17:17:51 from (63.99.111.183):
In Reply to: Re: rear tires posted by RustyFarmall on January 11, 2008 at 13:33:51:
It should also remind everone how important the quality of the tires is on a tractor you are considering purchasing.
I often wonder how many of the rich collectors discard perfectly good tires to get a matched set or get rid of some weather cracks. There needs to be an exchange set up for them.
Kind of like cracked H heads.
