Farmall M with a miss
Posted by sven on January 11, 2008 at 13:55:09 from (216.193.143.21):
Hi, I have an early farmall m with a mag that runs great while the engine is cold. However as the tractor warms up it developes a slight miss that only seems to gets worse as the engine gets hotter. There seems to be no power loss because of the miss and the engine still runs smooth under load. The engine just dosen't per like when it is first started and the miss occurs at different internvals. I have had the mag worked on, and put new points and plug wires on it recently. I believe the fuel system is working correctly and the tractor uses no oil. Could there be a problem with the valves as the head get hot, i have never had the head off.
