Re: Farmall M with a miss
Posted by LN on January 11, 2008 at 16:20:47 from (66.133.174.249):
In Reply to: Farmall M with a miss posted by sven on January 11, 2008 at 13:55:09:
I WOULD RECCOMEND RUNNING A COMPRESSION CHECK
ONLY TAKES A FEW MINUTES AND WILL TELL YOU IF YOU HAVE MECHANICAL PROBLEM, ALSO YOU CAN CHECK VACUUM WITH A GAUGE SHOULD HOLD STEADY IF IT BOUNCES AROUND INDICATESVALVE TROUBLE OR BROKEN SPRING ALSO AS THE OTHERS SAID CHECK VALVE ADJUSTMENT
