Re: Super A Hydraulic Pump Problems?!
Posted by Stones Throw Farm on January 11, 2008 at 14:07:19 from (64.12.116.73):
In Reply to: Re: Super A Hydraulic Pump Problems?! posted by Janicholson on January 11, 2008 at 11:24:45:
Excellent suggestions....but unfortunately no luck yet?!
The pump appears to be the original Pesco. Theres no hole for priming.
I tried the ditch and put 30psi to the filler hole. It did seem to help push fluid through as it took the other two pints the specs called for but ultimately the pump still doesn't seem to be building any pressure.
Any other thoughts?
Is it time to dismantle this thing and try again on the rebuild?(the pump did move oil before I put it back on the tractor - I filled it and turned the external gear and oil came pumping out...so I'm not sure exactly what else to look for)
Thanks again...
