IH656 Draft and Raise Lower Shafts Leaking Fluid
Posted by skyharborcowboy on January 11, 2008 at 21:21:43 from (75.211.109.122):
On the tractor that I just bought the control rods for the draft and raise/lower shafts are leaking. I have seen many others 656, 666 etc doing the same. I just bought the o-ring seals to replace the ones on the tractor. How hard is it to replace them? It seems I need to remove the seat and the housing cover under the seat to access an E-Clip to allow the rods to be slid out and then just replace the seals and reverse the removal procedure.
Do any of you have any tips/suggestions for me?
Thanks,
Joe
