Re: IH656 Draft and Raise Lower Shafts Leaking Fluid
Posted by skyharborcowboy on January 12, 2008 at 17:56:57 from (75.211.33.22):
In Reply to: IH656 Draft and Raise Lower Shafts Leaking Fluid posted by skyharborcowboy on January 11, 2008 at 21:21:43:
I posted a question about my hydraulic system and since the subject relates here as well I figured I would give you an update as well.
Here is an update. My neighbors son jumped up on the tractor today and grabbed the steering wheel to lift himself up. I noticed that the wheel was just spinning with no resistance whatsoever which didnt seem right to me. The steering is now much worse then earlier reported. There is fresh hydraulic fluid in the tractor. I need to locate the filter as I am not quite sure where it is (I havent seen any photos of its location yet). The level on the dipstick is correct. How much higher (on the dipstick above the full mark) would it be with the extra 5 gallons?
Thanks,
Joe
