Re: Farmall 100 Steering Repair
Posted by Haas on January 12, 2008 at 06:53:19 from (12.65.30.57):
In Reply to: Farmall 100 Steering Repair posted by Lewis on January 10, 2008 at 18:45:49:
Do you have any end play in the steering wheel shaft?? Any end play will result in loose steering. You state the bearing at the end behind the hex plug on the steering grear is good. However, are you sure the plug is in tight. The hex nut on the end of the shaft that holds the bearing in place must tightly clamp the inner race of the bearing against the shoulder on the shaft. The big hex plug must clamp the outer race tightly against the steering box. I found it necessary on occasion to install a machine washer behind the plug to get it to clamp the outer race. If you put a washer there, make sure it does not contact anything but the outer race.
