Posted by El Toro on January 13, 2008 at 05:50:08 from (64.12.116.73):
In Reply to: Re: 48 cub mag. posted by funtime on January 13, 2008 at 05:28:27:
The gap is .013" on a mag. You always need to to see where the rotor is pointing before pulling a mag or distributor, then don't move the engine for any reason. Put the rotor in the same position when the mag was removed and reinstall on engine. In your case you will need to pull No1 plug near the radiator and bring No1 piston to TDC on the compression stroke. Hold your thumb over the plug hole while someone hand cranks the engine. Once you feel compression keep slowly cranking until your timing marks are aligned. Turn the rotor to the No1 plug tower and install mag. Hal
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
