Re: Cub Hydraulic Pump Seal
Posted by El Toro on January 16, 2008 at 04:08:02 from (64.12.116.73):
In Reply to: Cub Hydraulic Pump Seal posted by Ron Weber on January 15, 2008 at 20:32:30:
I don't have a breakdown on the Cub's pump, but this one may be similar. It's fairly common for these old seals to become harden and then wear a groove in the shaft. Napa has speedi-sleeves and Case/IH should have them too. The same thing happens to the hub on the crankshaft pulley and will cause an engine oil leak and a speedi-sleeve
will cover this worn area too. Hal
third party image
PS: Speedi sleeve on a pulley hub
third party image
