Re: Swapping Mag for distributor
Posted by JT on January 16, 2008 at 07:03:46 from (70.226.195.180):
In Reply to: Swapping Mag for distributor posted by Mifsud on January 15, 2008 at 18:18:12:
I personally would not go to a distributor set up, I like the mag, the fact, if battery is dead, crank will start it, or you can pull it to start, mags are not a scarey as people make them to be, they are very simple to work on. They seem to be a lot more reliable than battery ignition. My m had a distributor, that is now on the shelf, every time I went to use it, I had to file the points or fiddle with it, I have mags on all my tractors, and I have not touched them since I put them on.
Jim
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
