Swapping Mag for distributor
Posted by Mifsud on January 15, 2008 at 18:18:12 from (207.200.116.7):
Looking to replace the Mag on a cub (1947) with a distributor and coil set up I already have. It is a 6 volt set up. Need to know the proper way to replace one with the other. The original mag is still on the tractor but for some reason the inner parts where removed. I have the head off of the tractor now because I just lapped the valves. Never replaced one before so I need some good info. on the correct procedure. Also how do you check the coil to see if it is 6 or 12 volts. Thanks
