super m sleeve question
Posted by glennster on January 16, 2008 at 11:18:17 from (76.224.13.122):
putting sleeves in the super m today, tisco kit from this site. when the sleeve is fully seated, i am getting about .015 of the sleeve sticking up above the block. the grooves are all clean and the sleeve is all the way down. is this within tolerance or do i need to get the sleeves surfaced down a little so they are flat on the top ?
