Re: Farmall 130 Engine Rebuild Kit
Posted by Hugh MacKay on January 17, 2008 at 02:19:39 from (216.208.58.158):
In Reply to: Farmall 130 Engine Rebuild Kit posted by Lewis on January 16, 2008 at 18:25:33:
Lewis: Unless someone has bored the engine, and after 50 years there could have been a good reason for doing so, you should be able to order an engine kit as per engine block part number. I 've done this about 6 times, lifetime and it always works.
Two things that confuse parts guys with these little tractors are boring to modify for another kit, and switching engines. It is possible to put a C-113 engine from one of the earliest A into a late model 140. Parts guys have been burned on this one quite often, thus they tend to make sure you are sure of what you have. No one likes to face an angry customer coming back with a kit that doesn't fit. They have an unhappy customer, a kit that has been opened from packaging, and possibly scratched from trying to put a sleeve in the wrong size hole.
If your 100% certain it's never been bored, the block part number will work for ordering a kit. If your not certain take Hal's figures, and check them against your engine.
