The C113 engines used sleeves that were 3 5/16" at the seal and were 6 7/8" long. To make it even more confusing the Super A's used the C113 engine and some of the later tractors had the C123 engine, but used thicker sleeves to keep the 113cid. Then the later tractors had the C123 engine with thinner sleeves to boost the cid to 123". Measure the old sleeves. Be sure to clean that block area where the seals are of all rust and dirt. A wire brush on a drill motor works well. This will let the engine cool better and keep those seals from leaking. Hal
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
