You need to take the pump off. Never mind about the # you first have to take pump apart to check the surface of the shaft where the seal rides as you probably will need a speedy sleeve on the shaft then you can see which seal you need so take it off and get started.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
