Re: what does it do? how does it work?
Posted by billde on January 17, 2008 at 05:58:34 from (72.26.91.191):
In Reply to: what does it do? how does it work? posted by funtime on January 17, 2008 at 02:58:20:
The push pull switch is the ignition switch. Out is run, in is off. If it has a mag, in grounds the mag to kill the engine, out is run.
