The push/pull switch is for your ignition. Pull it out before you start the tractor, and push it in when you want to shut the engine off. The person that sold it to you should have shown you that if you bought a running tractor.
The knob is the charging/light switch. On a stock 1948 Cub the first two positions are low charge and high charge. The third and fourth positions are dim lights and bright lights. Right after you start the tractor, you should have it on high charge. After a few minutes, you can turn it back to low charge.
If the knob goes click-click-click when you turn it, you have a four position switch. If it only goes click-click, it's a 3-position switch.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
