Re: Hey You Smart Guys!
Posted by PatMz on January 17, 2008 at 06:52:56 from (64.25.14.124):
In Reply to: Hey You Smart Guys! posted by Allan In NE on January 17, 2008 at 05:18:17:
Mine is mounted at the front left of the engine, above and outside of the water pump. There's a bracket that gets bolted down under the headstud at the front of the block. Right now it's just kinda cobbled up there with good old baling wire, but's been hanging in for five years because I was too lazy.
The pump mounts to the governor housing, using the cover plate bolts, witht the reservoir directly above it. Shield the hoses from the manifold! I'll try to get a pic for you.
