Re: Super A Hydraulics - Still working on it
Posted by Gene-AL on January 17, 2008 at 09:18:16 from (72.147.114.182):
In Reply to: Super A Hydraulics - Still working on it posted by Stones Throw Farm on January 17, 2008 at 05:45:58:
Brian,
I re-sealed the hydraulic pump on my SA a long time ago, but I just don't remember if the pump drive gear is locked to the external pump shaft with a woodruff key & keyway. If so, is there a chance that your key is missing allowing the gear to slip on the shaft under pressure?
