Re: Super A Hydraulics - Still working on it
Posted by Stones Throw Farm on January 17, 2008 at 10:08:52 from (64.12.116.73):
In Reply to: Re: Super A Hydraulics - Still working on it posted by Gene-AL on January 17, 2008 at 09:18:16:
Indeed there is a woodruff key. Its locked in solid. But in that same vein I spoke with a guy that had the nut that holds on the drive gear come off and end up in the fly wheel housing...or crankcase...or somewhere I'm not sure exactly where he found it but talk about a nightmare over a tiny nut. I suppose a real good bend in that lockwasher is order : - )
