Re: Hey You Smart Guys!
Posted by dzwoodcutter on January 17, 2008 at 16:18:21 from (216.9.165.204):
In Reply to: Hey You Smart Guys! posted by Allan In NE on January 17, 2008 at 05:18:17:
I've put that type of resevior on two of my M's so far. To mount it you need a piece of steel about 1/8" thick by 1" wide bent into an "L" shape. Short leg of "L" is just long enough to fit under nut on front head stud with hole to match stud diameter. Long leg of "L" fits against side of resevoir with top of leg against flange at top or resevoir. (make the length of this leg whatever you need to locate resevior at height you want. Long leg of "L" bracket is fastened to resevoir with worm gear type hose clamp around resevior and long leg of "L" bracket.
