Posted by KJFarms on January 18, 2008 at 05:42:58 from (143.79.13.6):
In Reply to: 1206 Oil and Water posted by rdw on January 17, 2008 at 17:32:34:
Can be series of things. I'm going through the same thing right now. Has the tractor been running hot? If you have a cooling system pressure tester. Put about 18-20 psi to the cooling system, and pull the oil pan. Look for water dripping from the cam shaft side of the engine. If you see water drips it's head gasket. If you see water drips from the bottom of the sleeve, its a sleeve problem. Hope this helps.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
