Re: H countershaft Install Question
Posted by Bob Kerr on January 18, 2008 at 20:31:35 from (205.188.116.73):
In Reply to: H countershaft Install Question posted by neblinc on January 18, 2008 at 12:34:38:
I hope that picture is when you took it apart. One thing I noticed is the color of the shaft where the rear bearing goes like the bearing locked up and spun on the shaft. Is that black or bluish in color? Make sure there is no grove worn in the shaft or it may make noise if the shaft is sloppy even with new bearings on it.
