Re: Super H, Kelly loader , Moving bales
Posted by Allan In NE on January 19, 2008 at 07:54:25 from (148.78.243.24):
In Reply to: Super H, Kelly loader , Moving bales posted by VA Gasman on January 19, 2008 at 05:32:54:
Used to rountinely stack hay as late as 1974 with the F-10 mounted on an H.
Ya just haven't put up hay until you've pushed 2 ton of heavy alfalfa hay up some 27' over yer head.
Gives me the shakes just thinking about it. Those were some huge stacks! :>)
Allan
third party image
third party image
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
