Super H, Kelly loader , Moving bales
Posted by VA Gasman on January 19, 2008 at 05:32:54 from (69.72.101.180):
I have been using a super H for 3 years to move 4 x 5 bales (800#)from storage to feed area. I never lift them more than 12-18inches off the ground . Transport 100 yards or less. Tires hold up good . Makes steering a little difficult. Loose a lot of rear traction But get the job done. Only feed 25 bales a year in this goat ranch operation. An old friend says I am putting to much on the tractor. Any body else feeding with H ?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
