53 Super H with no hydraulics?
Posted by migraine on January 19, 2008 at 08:32:41 from (67.182.151.248):
Have 53 Super H ser#16785 that appears to be a hydraulics delete ordered tractor. Has the belly pump delete cover that appears to have never been off and PO added a live pump and reservoir off a 54 and moved the battery under the seat. But since this is a 53 and has the starter and the belt pulley on the right side they mounted it on the left side including the control Rod. Kinda of a cobbled up mess and I think I will take it all off and start over. Could you order it this way with no Hyd.? Last question. the grill has the two center holes and has the solid blanks on the two bigger outside holes never been punched out. Never seen one like this before. Any Ideas? Thanks Migraine
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
