Re: Super H, Kelly loader , Moving bales
Posted by co2bb on January 19, 2008 at 09:47:35 from (69.40.148.197):
In Reply to: Super H, Kelly loader , Moving bales posted by VA Gasman on January 19, 2008 at 05:32:54:
I also have a Super H class 2 with a Kelly Loader on the front, wide front end, which has been return to showroom new. Is your H a wide front end and does your Kelly loader have the manure forks and the snow bucket attachment.
The H here is used mainly for pushing snow back as we live right on the edge of the snow belt here in Central NY The lake effect can be bad here at times, also push snow with a Super A with blade and a Cub with a blade. Each tractor has chains and weights Can never have enough tractors ready to push snow in Central NY
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
