Re: Super H live hydraulic upgrade
Posted by pat in wis on January 19, 2008 at 15:31:32 from (216.146.79.130):
In Reply to: Super H live hydraulic upgrade posted by Piston Pwr on January 19, 2008 at 15:14:19:
1.Original gear should be heavy enough to run pump
2.Depending on how much reservoir is needed probably an external tank ( belly pump don"t hold alot)
3.If it was mine I wouldn"t run hyd oil in rear end - but depends on how hard its used I suppose, hytrans lubes fine in my 806 rear end though
4. I would leave belly pump in( its already there and you might want another hyd circuit in the future for something)
5. Will you need "float" as well as down pressure?
6. Filters are always a good idea
hope this helps some, others might not agree, just my thoughts, Pat
p.s.- what state do you live in? will you be using it mainly in winter for snow etc?
