Re: Super A 3 point hitch - Think I am done. For now...
Posted by SteveNH on January 20, 2008 at 08:25:20 from (71.161.96.43):
In Reply to: Re: Super A 3 point hitch - Think I am done. For now... posted by bhb on January 20, 2008 at 07:57:49:
I attached the upper link to a bracket that mounts to the rock shaft, that was one of the pieces from the Worksaver setup, it attaches to the rock shaft using muffler clamps. I did have to cut it a little to fit, not sure if it was meant for mine or the 100 series, but it was easy to get it to work.
Yea, that"s my Electra Glide hiding out under the sheets - I have all sorts of toys and little time to play, but I never have a lack of stuff to do.
Thanks again for keeping me on track Hugh, I will look at the plans, it didn"t look quite right, but then again I am not sure what right is. I wasn"t sure if they had to be tight or not, that is why I bolted them, I guess they can have a little movement on the pins then since the non threaded section is wider then the ball on the link?
