Re: Farmall H restoration information request.
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by The Red on February 28, 2000 at 03:20:14 from (12.75.197.216):
In Reply to: Farmall H restoration information request. posted by Jim Radley on February 27, 2000 at 20:05:38:
Jim the vertical distributor was an aftermarket when someone converted from magneto. My grandpa's 1941 H is like that.
I would suspect on the oil pressure that the gasket in the pump is leaking. That gasket is paper thin. Yes the oil pressure drops after you warm up but no more than maybe 10-15 psi on my 3 Hs.
On the water pump, additional packing material should stop the leaking.
Post A Followup
: Re: Re: Farmall H restoration information request.
