Re: Carb, coil, tune up info C-263 gas
Posted by bc on January 21, 2008 at 09:16:36 from (70.130.54.235):
In Reply to: Carb, coil, tune up info C-263 gas posted by bc on January 20, 2008 at 16:31:32:
Thanks Glennster. You may be right about the float. I bent it around to adjust it and it might be scraping the bowl or gasket now. I also had the gasket sitting on the bowl instead of on the throttle body above the float when I put it together and some of the excess gasket may be hanging it up. I think I also forgot to shake it to see if I could hear the float moving up and down this time. I'll get a new one even though this one still seems to be airtight.
About the coil. Mine is 12v. on a C-263. I looked at the caseIH website for a picture and mine does not have an external resistor on it. Do I need one and should I get one? Wouldn't any extra amperage help the spark? If a weak coil is part of my problem, it doesn't seem right to reduce it down. I kinda thought the hotter the coil the better unless there is something else going on here. Thanks again.
