Re: Carb, coil, tune up info C-263 gas
Posted by Lynn Davis on January 21, 2008 at 12:12:40 from (88.202.52.13):
In Reply to: Carb, coil, tune up info C-263 gas posted by bc on January 20, 2008 at 16:31:32:
I'm guessing with a C-263 that you have a 12V system, go with Glennsters advice on coil. Explanation; coil works with specified volage but 12V will burn the points, external resistor should be between coil and points to reduce voltage at points.
