Re: Fender Brackets
Posted by SDE on January 21, 2008 at 16:53:11 from (69.179.25.120):
In Reply to: Fender Brackets posted by Chris450 on January 20, 2008 at 16:30:09:
I am going to guess that they were about 1-1/4" long. Maybe they were only 1 inch.
They are long enough to provide enough clearance to go over the hitch to axle bolt, which is at least 3/4".
It is to cold for my lazy butt to go outside.
SDE
