Re: Brain fart
Posted by John S-B on January 22, 2008 at 20:31:07 from (205.188.116.73):
In Reply to: Brain fart posted by F150Mustang on January 22, 2008 at 13:27:29:
I had an old Dodge Charger POS. I was driving it one day when the bolt holding the steering column to the firewall fell out! (dunno what happened to the other one) The u-joint did'nt come apart so I could still steer, did make me pucker for a sec.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
