Re: BELLY PUMP FOR SUPER M
Posted by Tractorfan1 on January 23, 2008 at 05:11:55 from (142.167.72.121):
In Reply to: BELLY PUMP FOR SUPER M posted by JMP on January 22, 2008 at 22:38:20:
SD FARMALL said: (quoted from post at 23:38:20 01/22/08) I have a Super M with a belly pump on it. First question is it actually called a farmall liftall or just a plain belly pump? Second question on the vent/filltube/return keeps spitting fluid out, is this cause its overfilled or is this normal? Wouldn't think its normal. I'm running a CROSS 3PT with it and 3PT runs great, only problem is the overflow from the vent cap. Do I just need a longer neck on the tube or do I have a problem?
Thanks,
Eric
To answer your first question, yes its called a Lift-All. I also have a Super M with the Lift All, but it doesn't leak out the fill tube. Maybe yours is overfull...
