Re: BELLY PUMP FOR SUPER M
Posted by Nebraska Cowman on January 23, 2008 at 10:42:47 from (65.162.146.181):
In Reply to: BELLY PUMP FOR SUPER M posted by SD FARMALL on January 22, 2008 at 22:38:20:
If the return line from your two-way valve is plumbed in the filler pipe you may get some burping. You can extend the pipe to help stop overflow. Another way is to plumb the return into the drain in the bottom of the sump.
