Re: Checking H differential gears
Posted by r4etired on January 23, 2008 at 18:36:56 from (166.226.126.205):
In Reply to: Checking H differential gears posted by neblinc on January 23, 2008 at 06:55:04:
First of all you should put the front bearing in and the bearing cage bolted up tight. I learned from experience put the same shims back in you took out, reshiming used gears is almost a guarantied noisy rear end. the book recommendations for backlash are for new gears. Sometimes just putting the O rings on the cage will affect the settings. This is my 2cents worth.
