Checking H differential gears
Posted by neblinc on January 23, 2008 at 06:55:04 from (76.79.15.57):
I have the tranny & differential put back together using all the original shims in the same place. I am really confused reading the service & IT manuals on adjusting the backlash. Does the main trans shaft push to the rear when under load? If so I have very little play in the mesh of the gears and think it's ok where it is. But if I push on the rear of the trans main shaft, I get quite a bit more play between the gears.
Randy
third party image
