Posted by FC Andy on January 23, 2008 at 18:42:44 from (216.68.248.2):
Does anybody know when replacing the throw-out bearing on a C if the bearing should press on to the casting that it rides on or should it be a slip fit or does it really Matter? The old bearing on mine pressed off, but the new one is just a "good" slip fit. Is that the way it should be? Or Should it press? Is there much clearance between it and the fingers on the clutch for it to fall off the diameter? (there is a relief diameter all the way up to the diameter the bearing seats on, for roughly 3/16". Thanks everybody for your input.-Andy
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
