Re: Farmall Injectors
Posted by K.B.-826 on January 24, 2008 at 15:08:25 from (24.180.154.16):
In Reply to: Farmall Injectors posted by Dubl J on January 24, 2008 at 14:53:05:
All 361"s had the same injector body, so the difference from a D to a DT is probably the tips. One probably has more holes or different sized holes. Since they"re going into a DT, I"d say use the ones from the DT. If these are used injectors they should at least be tested first.
