Re: Hydraulics and water question
Posted by gene bender on January 24, 2008 at 16:42:57 from (67.55.226.214):
In Reply to: Hydraulics and water question posted by grizzthebear on January 24, 2008 at 15:44:50:
You will need some ports added for aux hy. Yes you can put a water pump fro an C on your engine. Your HY pump will putout 1000 or more at 10gal flow if in good shape so you will need a hy motor that doesent need more than that for your mixer. The HYDRO-DRIVE is a hy motor that rons off the system on the PTO and will move the ground speed of the tractor with the clutch depressed. The stuff you want to do needs good knowledge of hy systems before you start so get all the info from the equipment before you try to make it work.
