Farmall H crankshaft question
Posted by Singlecylinder on January 24, 2008 at 18:26:57 from (98.132.205.243):
Can I use an older crankshaft in a newer engine if I replace the bearings with the correct size ones? Are the bearing outside dimensions the same on both engines so the bearings would fit in either block? Just the crankshaft journals different diameters?
