Brakes growl on IH 706
Posted by jd720spec on January 24, 2008 at 18:58:43 from (70.100.2.76):
I have an International 706 with the D282 engine that I have rebuilt, the engine runs good and the clutch is good since I put a new clutch and pressure plate. The only thing that concerns me is that the brakes work but they make a loud growling noise when applied. The Hyd fluid has been changed as well as the filter. The tractor has sat for 15 years outside before I rebuilt the engine. I was thinking that the brake drums are just a little rusty and maybe need to be used to quite them down. They do work but make a loud growl when the brakes applied until the tractor stops moving. What is your suggestion remove the brakes and look inside?
or use the tractor for a while and see if it quiets down. It shifts fine in all the gears and pto works.
