That is on the high side (maybe .4 volts too much) but Regulators are often temperature compensated and when they are cold, they charge more volts. I would run it the way it is (and watch the battery water level if it has caps) until spring and 50+ degree weather. Batterys can be just fine on that diet of input when cold. Cars often put out 16+ volts into batteries in the winter. If it does begin to heat the battery, or continues to charge high when thew temp is warm, I would adjust the VR (using a good old electrical system manual from Motors, or an older generator friendly text. The type is a Delco "A" system. Good luck JimN
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
