Re: radiator ? for a H farmall
Posted by GordoSD on January 26, 2008 at 07:29:15 from (66.115.200.140):
In Reply to: radiator ? for a H farmall posted by Booth2563 on January 26, 2008 at 07:01:39:
I just made up two the other day. Used a 4 1/2 inch 7/16 NC grade 3 bolt. Cut it to correct length. Then threaded the smooth end about 3/4 of an inch down with the correct NF die. Then drilled the hole for cotter pin. Picked up two new 7/16 NF castille nuts at Menards. Total cost $1.60 vs the 15 dollars the IH dealer wanted.
And Menards had a 5 inch piece of 3/8 pipe for the drain pipe also.
Gordo
