Moving the lever: kind of an overcenter setup is part of what you describe, a little lubrication might help if you can get it to the right spot. There is a spring that helps throw it up. If it freewheels its broke. But don't use it as a brake, only to downshift under load. You can use it up and down hills if that is the gear you find that fits yuor needs. And about every thing else I've seen in the replies.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
